P38 - upgraded control board and not working
rhschumaker
37
Western MA
I just installed the upgraded control board for the P38. Put it all back together and everything comes on like it's running when I plug it in - even though the stove is turned off. Any ideas? Hoping this is a quick fix.
did you set the board correctly for the ESP probe you have?
It appeared on my old stove that the differential switch was wired through the neutral and on this version it appears to be wired through the positive. Does that make sense? I wired it through the positive per the diagram
the #5 dip switch has to be set according to you ESP probe wire color. My guess is the default is for red, and you have black wires.
we have exercised the demon! Go TEAM!
Reactions: 2011 GT/CS and Jags
