Observations on the new Harman 52i Insert
There you go... My super conductive pellet stove yet to be designed will have a copper heat exchanger
Maybe you can integrate it into a solar array as a conductor.
Chit...throw a battery in there too.
Reactions: Lousyweather
My issue with the hopper lid is that pellet get behind the lid very easily and then the lid won't close right but you cannot remove the pellets from under it either.
I actually thought this was far worse on the older, older accentra insert, before the hopper lid latch upgrade. the current one I just push the stragglers all the way back and when I close the lid they are behind the lid, rather than under the seal. the older one with the ball spring latch had a strange metal flap that help the stragglers hide from you.
great.. now our stoves are going to get robbed and sent to the scrap yard :/
I still have not put my hands on one.
Eric
The heat exchanger plates on my new 52i are magnetic. Rules out aluminum, also my unit got very quiet after the third bag of pellets. Before that it did make some "extra" noises-thought I was going to have to do some investigating!
