Yeah, I saw a nut underneath that could easily have been mistaken for some of my welding! But the overall feel is of a very solid box. It has the ashpan option, and unlike the PH, the pan is welded on (fewer gaskets, fewer chances for leaks). I just checked with a flashlight, and that long weld was definitely not one of mine.Like nothing else on the market....way to go woodstock for being bold! Some of the welds look like mine, but hopefully they'll get that figured out.
Nice to see another big Cat stove on the market.
I think I read somewhere that they have a summer date in mind. I have the luxury of being close to the factory, so when we bought the PH we drove up to see it and bit the bullet before they had delivered any. And then sat here and suffered for months as other here started receiving their stoves and telling us about it.Any info when it will go on sale?
So this stove can run on a 8" chimney?Note the taper down to 6"
I don't know about the 8" possibilities. They said the taper was to let it breath a little easier in the top-vent position.So this stove can run on a 8" chimney?
If the price is around $1500 this will be my next stove.
Yes, the gears are for cooking on. My wife is voting for them to go away (looks-wise), and it is simple to do, but we have been running the tea pot on one of them.The basic stove has a clean, contemporary look. I don't need the decoration, but to each their own. Are the gears a stylized version of a functional trivet? Maybe it just keeps the top from being marred by teapots and pans?
Thank goodness they didn't bring out the version with the horizontal lady!
Thanks for posting this and taking such great pictures to document it. Your old farmhouse looks beautiful.
Todd, our damper plate was a little off-kilter, but a call to Woodstock got us back in order, and we are just starting to get a sense of the degree of control. I've felt the first half of movement of the PH damper control (from wide-open down to mid-range) has little to no effect.The Ideal Steel feels more balanced in that regard. Right now we are burning a fairly full load, 520 stovetop and 500 degree Condar probe (about 16" of flue from the stove) - initial feel is same heat and more fine-level control than the PH.Thanks for sharing, it will be interesting to see how it compares to the PH. I like the looks except for that big square door.
I think it is pretty similar to the PH on the top end. It is slower to start a load in the Ideal Steel, and it takes longer to burn down a deep bed of coals (there is a stronger primary draft at wide-open with the PH). I think the PH gives us a more balanced heat at the top end. Practice with the new stove will likely cut down on the differences we get, but they are different.How's it been heating your house in the frigid weather compared to the PH?
Heck when it gets down below zero f I bet most stoves struggle to keep up.
The air control on the low end is much more fine-tuned as compared to the PH. No back-puffing with the Ideal Steel. Able to take it down to any degree of secondaries I wish to. I want this for my PH!!
Our house is old (1797). The house sits on a dry-laid stone foundation with an uninsulated front walk-out basement wall of brick - it is airy and exposed on the bottom. The walls are pre-2x4 vintage, the wall cavity is 3" at best. I would be hesitant to compare stoves using my heat loss and square footage as the basis without a generous old-house allowance.all I can add is not the right stove as I am in Iowa where 10 degrees or lower is quite common. even with the old stove it is all we use for heat.even the new stove the isle royale has no problems so far even double digit below 0 with wind has not been a problem.and we are quite comfy in 2500 sq ft.
No, I'm not sure. Certainly lighter than the PH. It does have a stone-lined firebox, but only decorative stone on the sides, and none on the top.Do you have any idea on how much it weighs?
Not an accurate measurement because it is hot, but 15" from the bottom of the door frame to the top of the glass. Looks like probably a little more than that inside the firebox. There is a swinging smoke baffle at the top of the door, but we've had our locked in the up (retracted) position, with zero smoke issues. The secondaries baffle slope down toward the back, so less room as you go deeper into the box.Flamestead, the question has been answered on the width and depth of the firebox, but I'm curious about the height.
Looks fairly tall in there.
