I've always had carbon on all three of my stoves, although the St. Croix isn't as bad. I just use a very sharp 1" wood chisel and a 3M diamond impregnated sanding pad (green). If you search all my posts you will find out where you can get the pad for $34.00 at MSC..I wouldn't use the graphite paint unless it was very high temperature paint. I would guess it would be very expensive.Burn pot carbon build up is expected, but it is a little annoying. Any one care to share their solutions? I'm considering media blasting my burn pot and coating it with a graphite paint, but have to do my research first. View attachment 141586
******Stevekng, I checked your posts but couldn't find the 3M info.....What is MSC? Thanks, BillI've always had carbon on all three of my stoves, although the St. Croix isn't as bad. I just use a very sharp 1" wood chisel and a 3M diamond impregnated sanding pad (green). If you search all my posts you will find out where you can get the pad for $34.00 at MSC..I wouldn't use the graphite paint unless it was very high temperature paint. I would guess it would be very expensive.
When I use the chisel and pad, it takes me less that 5 min. to clean the carbon off completely.
**********Just found them on Amazon, but what Grit do you use? Saw some from 100 up to 800. You must be using a very course pad, right? Thanks again, Bill******Stevekng, I checked your posts but couldn't find the 3M info.....What is MSC? Thanks, Bill
Here's a picture.**********Just found them on Amazon, but what Grit do you use? Saw some from 100 up to 800. You must be using a very course pad, right? Thanks again, Bill
I built concrete counters for my home, and used diamond grinding wheels and polishing pads, from Concreteexchange.View attachment 141626 Here's a picture.
Here's a link. http://www.mscdirect.com/product/details/01054659
