Well, i think I need a new blower motor. It is making a high pitch squeal. Wheres the cheapest place to get this. Parts unlimited has an aftermarket one for $150... anyplace else?
Have you tried putting a couple of drops of oil
in the 2 D holes . Maybe the bushings are dry ?
Yeah I just went through this with my EF2. 2 drops of oil in each of the D holes did the trick, but oddly it took a couple days before it completely quieted down. And yes, the room blower is a ventriloquist. It squeals, but the sound seems to be coming from the exhaust side.
Apparently Fasco recommends this fancy oil for their high-temp fans. I bought some, but only after I'd already used plain old 3-in-1 oil. You could also use this version of 3-in1 oil, made especially for electric motors, and it meets the spec required by Enviro for only $3.
That's not what I have. What you're holding in your hand looks like an adapter that is plugged into the wiring harness. You probably have an aftermarket fan, and that adapter allowed the installer to connect that fan to your wiring harness. If you remove that adapter your new fan "should" connect into those two white boxes in the lower left. Those blue and purple connectors should be the same type you're seeing on the replacement. Explains why your oil ports weren't oriented so you could reach them with the fan installed
I'm in the process of rebuilding mine right now. Just waiting to get the ambition up to run in to town to get the bearings.
The worst part is getting the plastic squirrel cage fans off...takes a bit of patience!!I dont think I am that mechanically inclined
