Am I cursed???
Sears rider.
New battery, new spark spark, and no juice. No Wanna start, no nothing.
Model # 917.272680
Sears rider.
Model # 917.272680
Never had that problem with a horse. Any chance she can pull a mower?
I hate those safety switches. I leave most of them enabled except the worst one of all. the one that kills the engine if you try to go in reverse with the pto engaged (ie blades rotating). That is the first thing i disable when i get a new rider. It is a rider mower, who in the world doesnt look behind them when backing up with the blades turning? if i need to backup i usually just back up while my head is turned to see back there anyway.
No safety switches on them??
Huh? Homeowners on zero turns throw one lever into reverse at every turn. Pros generally do K-turns, to avoid turf tearing with wide rear tires, and so are throwing BOTH levers into reverse at every turn.They have safety switches, but you don't do much backing up with a zero turn.
My commercial Deere 757 ZTrak has only one safety switch, can't get off seat for more than 2 seconds with mower deck running.
