OK.. what tire size do you use?
author="Jags" date="1197926036
12.3 Pounds at 4.4 hp. Makes for VERY efficient cutting. Less work than my old saw at 9 pounds. That IS working smarter.
That is the weight of the power head alone. Now remember you have to add gas, oil and which ever chain and bar you desire!
Must be real easy cuttin those 48"ers pullin that starter rope with no bar and chain!
Usually I try to cut with the bar and chain in place. :coolsmirk: The point is that just because chainsaw xxxx is lighter than chainsaw yyyy, doesn't mean it is less WORK to operate.
author="Jags" date="1197928712
Stihl is quality and the 361 is high end, no doubt about it, and you probably spent $700+ for the saw. But I doubt 'most' want to lug that around their wood pile cutting rounds that are 'usually' less than 16"s. Now if they were clearing lots or logging that would be another story.
Like I stated earlier in this thread.....I got big wood. ;-)
Any size works. If there is too much space, add extra wood as padding.
Don't forget to drill holes into the sidewalls so that water won't accumate; no one wants to breed extra mosquitoes since there are so many already to attack while splitting.
Another handy trick: wedge your wood between logs.
Jim Walsh said:
Those familiar with maul splitting know this old trick.... now passing it along to others,
What size tire really works well?
Just right most of the time... ~ 18"x14" round red oak and split it in less than a minute:
Too low a profile?
Rimless and 14"?:
