1983 Blaze King Issue
seanc_mt
3
Lincoln MT
Ok fresh install ok a 1983 blaze king. 4 feet of single wall then 10 feet of triple wall that is 2 feet over the peak of the roof. New door gasket, catalyst is a bit worn. Once i get the kindling lit and stove plenty warm and can put 4-5 good size pieces in. turn the damper down all the way and its great, that is for 5-6 hours it will sit and smolder perfect putting out just enough head to heat my little apartment when temps are in the 20's. then out of nowhere it will just start heating up and cook me out of there. at first i though thermostat was malfuctioning so i pulled the cover at the back of the stove to discover it was still completely closed. do i need to install a damper in the exhaust side to keep it damped down? any ideas are welcome! thanks
Have you tried cleaning the cat and then pickling it?
@BKVP may know a bit about this stove.
