Excavator
I did not take shell apart on my 0028. I removed front doors then the damper, upper and lower fireback and then combuster and refractor. I used new gaskets including on front doors, griddle and ash pan
It is ALOT of work. The only reason I did mine was the rear casting had a crack near the where the flue collar attaches. If you do decide to go ahead make sure you have plenty of grinding bits and most important DRY FIT THE STOVE BACK TOGETHER before you start applying cement. Make sharpie marks on all wall to wall meetings, especially where the rear meets the sides and upper fireback. You might also need a second set of hands when bolting the ufb back on.My parts finally arrived for the 2550. I am debating, the stove at the moment is gutted, all of the inner parts are out. The outer shell is intact as well as the area underneath the refractory (where the throttle line runs).
Should I take apart the outer shell? This would then classify as a total rebuild, or should I bother?
I know some of the fellas here have done both, I need your opinion on how I should proceed. Ripping the outer shell apart would add substantial amount of labor hours.
+1 and burn dry wood [emoji13]Hot fire for the top section. Use a torch or don't worry about it in the ash pan but make sure there are no air leaks on the door into that area.
... This is the positive side of the internet and computers. We can search and find answers with just a little patience.
Wow wish you posted chandelier. The condor is very cheesy and it's expensive
(snip) I am wondering what type of probe is on the condom ...
I'm running a 2550.Wood use??
I have a VC large winter warm and I am curious about wood use. I know there are many variables on operation that impact this, but how much wood do you use on a typical day (24 hour burn), if the temperatures are in 20's or 30's (not real cold). There are many ways of quantifying wood use (# of splits, arm loads, wheel barrows, etc) but if you could describe it in wheel barrows or cubic feet, that would be of most help. I use a heaping 3 cubic foot wheel barrow (or a little more) on a typical day. I'm trying to see if my wood use is in line with others.
