A couple "rookie" questions.....
TaddHaynes
1
I'm looking at installing a VC Aspen into a clay tile lined masonry chimney. I need a bit of help before I get in over my head. It will be a hearth installation into a long unused fireplace that had the firebox painted (latex). With the radiant properties of the stove, will this create a problem- i.e.-should I strip??
Also, assuming I am using double wall stainless steel to vent through the top of the existing chimney, can anyone give me a rough estimate on what to expect financially for a professional installation (so I can try to get the pre-approval from my CFO wife!). Approx. 18-20 feet (1.5 stories).
Thanks for any help you can give.
I don't think you will have any problem with the paint. Latex tends to soak in and bond with masonry. Also, you are not applying direct heat to the masonry.....with a stove like that, you'll probably be able to touch the masonry at all time (it will probably be somewhere from 120-150 degrees)....not a problem for paint on masonry.
Double wall pipe is not needed. The chimney is already lined. A 6" stainless steel liner - flexible, rigid or some of each, can be dropped down the chimney and hooked to the stove - with a metal block off plate in the top of the fireplace. Depending on flue size and other factors, the best job involves wrapping special insulation around the ss liner.
A 20 foot job will run $1000 (uninsulated) to $15-1800 (insulated).
