A Good Stove For Me?
Djwood
2
Prince George
Hello,
Im new to the forum. Courious what you guys think. I currently run a wood master 4400 boiler to heat my house. Im looking for a more eff way to heat my house. Im thinking about installing a BK king stove in my basement. I can use my furnace ducts to move the heat around for the new wood stove. What you guys think ? My house is 2500 sqft.
Thanks
Check local regs. Ducting a wood stove may not be permitted.
How is the current system setup? Does the boiler feed a water to air heat exchanger that is then ducted? Is all the current ductwork tightly sealed and well insulated?
Are your foundation/basement walls insulated on the interior? Open floorplan with a open staircase centrally located?
May be worth considering a add on furnace if wishing to utilize the existing ductwork to full effect. If this is even a option.
Lots of expertise here but answering these few questions will help get the ball rolling with recommendations from the pro's.
My basement is unfinished. Its a log house. The staircase is off to the side. There is an existing electric furnace with full duct work to the top floor. I use this as a backup to the boiler. I have a heat exchanger in the ductwork . I just run the furnace fan to circulate the heat.
I thought of running the chimney througj the basement wall then up
Thanks
