adjustable stovepipe cap
pellet9999
119
ny
Is anyone selling an adjustable screened stovepipe cap that will clamp on 6 inch DuraTech insulated pipe...???
The DT version is too high priced..
Again you really can't mix and match components. And regardless the universal caps cost about the same
I could not use a selkirk sentinel cap on my supervent chimney
I got the ceiling box from DV. The ring on the bottom in 6 inch inside and 9 inches outer diameter.And yes there is a twist lock connector inside.
I want to run the cheaper single wall durablack up to the ceiling box.The top piece will be a 45 degree piece into the adaptor.One of 2 that I will need.
Then DuraTech double wall insulated above the roof. I will re use the 4 ft piece I have for that.
What is the product number on the ceiling box adaptor for using 6 inch durablack pipes inside...
I cant see one when I search the net.
Is this what you are looking for?
