So 2 hrs in to the 1st fire I really do feel like a traitor, cause I'm really enjoying this stove. Between the fan that my stove does not have and the beautiful finish, there is a lot to like about the Ashford. I fired it up at 1pm with 5 average size splits let's see how long this goes on low.
Sent from my SM-G900W8 using Tapatalk
That is too bad the sig feature is neglected. Most of us put what stoves we have and stuff like that in our sig to help prevent those kind of common questions. Is that why all your posts have that extra line talked on about what your posting with? I had a phone that did that once, shut that feature off right quick.Strictly Tapatalk user. I must have went to website to register but I don't remember. So I have know idea what your referring to. But I'll check it out
I had a legit installer do it top to bottom for my mother conscience. I ask him twice and so did my mother about that very question. He assured us that it is fine and showed us in the Ashford manual that minimum corner clearance is 4" and we are at 6"Stove looks mighty close to that wood paneling.. did you check the clearances?
Coke. Red Sox. Toyota.Because out of all of the great rivalries -- Coke vs. Pepsi, Red Sox vs. Yankees, Chevy vs. Ford, etc. . . . no one ever has Nissan vs. any body.
Can you describe the chimney setup from the stove up? What is the total height? From what I've read, the BKs wouldn't run on a 13' stack like the Fireview is doing at my BIL's house, even when it's barely cool outside. Not sure what the Woodstock hybrids' capabilities are in regard to short chimneys and warmer outside temps. It should be plenty cold up there now, so I'm guessing you have a short stack on the Ashford?Ok. So I've been having alot of problems with this stove backpuffing. I know it maybe do to draft but this is ridiculous, the Cat disengaged and danper 90% open and its still back puffing. So far everytime I try and run with the Cat engaged it will drop out of the active Zone and the stove with start emitting smoke from everywhere. Any advice is welcome
AFAIK, the Sirocco and Ashford have a different firebox than the Princess. They were tested with 15' flues and have always had that requirement.
Don't you use wood from the same stack in both stoves?Well. So far the Ashford is a really nice and efficient stove, does anything as advertised. I had some trouble with finding the absolute lowest setting on the damper. Turns if I set to as low as it could go, the fire would go out. I think it is lack of draft, we went with the absolute minimum stack height for the overall look of the exterior of the house. Also I don't like the ashtray system when comparing it to mine. Now I know ppl don't like a gasket seal ashtray but the convenience of cleaning is second to none. One last thing the glass gets dirty quick on the Bk, compared to my airwash glass on the PH which I haven't cleaned in over a yr. Granted my glass is due but that is more ash causing a blurry view as apposed to black sediment constantly on the BK. So after a 6 weeks or so BK and PH are about neck and neck heating and doing what a woodstove is supposed to do. Bk with the longer burn times, not by alot 15-20 percent longer. But the PH with the better Heat output and solid burn times. But where I found the PH out does the BK is smaller day to day stuff. I like drinking my coffee before work and watching morming reload burn up, and that airwash is there to make that happen. Cleaning out the ash is a breeze. And like putting Gas in her van, putting wood in the stove is something my wife just seems to forget! But no problem, the PH will pump out the btu's to heat the house warm real quick.
And the chimneys are identical?Well. So far the Ashford is a really nice and efficient stove, does anything as advertised. I had some trouble with finding the absolute lowest setting on the damper. Turns if I set to as low as it could go, the fire would go out. I think it is lack of draft, we went with the absolute minimum stack height for the overall look of the exterior of the house. Also I don't like the ashtray system when comparing it to mine. Now I know ppl don't like a gasket seal ashtray but the convenience of cleaning is second to none. One last thing the glass gets dirty quick on the Bk, compared to my airwash glass on the PH which I haven't cleaned in over a yr. Granted my glass is due but that is more ash causing a blurry view as apposed to black sediment constantly on the BK. So after a 6 weeks or so BK and PH are about neck and neck heating and doing what a woodstove is supposed to do. Bk with the longer burn times, not by alot 15-20 percent longer. But the PH with the better Heat output and solid burn times. But where I found the PH out does the BK is smaller day to day stuff. I like drinking my coffee before work and watching morming reload burn up, and that airwash is there to make that happen. Cleaning out the ash is a breeze. And like putting Gas in her van, putting wood in the stove is something my wife just seems to forget! But no problem, the PH will pump out the btu's to heat the house warm real quick.
It gets even easier if you don't put the lid on.The pan has a lid you slide on while you pull the pan out. It doesn't get any easier.
Yeah, it's weird we have the ability to turn way down past any useful setting, as I guess a lot of people probably run into a similar problem, but it actually works very well. Try a setting around 3 o'clock on the dial (middle of normal range) and do a full burn. Make small adjustments from there, to dial in on your desired burn time. I suspect there aren't many burning with a knob setting below 2 o'clock without stalling, but someone will surely chime in here soon, to disagree.Yup. The wood is from the same stack. I will say maybe I'm burning at too low, which is causing the black window. But that is because I'm having trouble with the damper. Which I could be another complaint. On my PH if I'm looking for "low" I just turn the damper all the way down. On the Ashford I had to find low on my own. If turned it all the way down the fire would go out. But hey it's still early in the competition, maybe by February I'll be loving it. Sorry if you couldn't follow my last post too well. Been busy with the holidays, and that post was hastily written in the mall tied the hitchin post with the rest of the husband's.
