I just purchased a Jotul F100 wood stove - it will arrive in a couple of weeks and I have a TON of questions.
Would like to install everything myself, have been told by a couple of local suppliers that this is not an irresponsible thing to try to do myself w/ no experience. The Jotul installation information and diagram from their website is helpful but leaves me with a lot of questions.
I also would like to buy the stovepipe and chimney pipe and all other parts online from a single source if possible.
I don't have an existing chimney. I have a single story home, 8 foot ceiling, 7/12 pitch roof.
I want to use double wall stove pipe so I can set the stove a little closer to wall while maintaining Jotuls defined clearances (plus a couple of inches to be extra safe).
I am top-venting my stove and going straight up and out my roof as high as possible for maximum draft. My chosen location for the stove will put the chimney through the roof pretty close to the ridgeline, going through 4-5 feet of attic space.
I am getting a new roof within the next month and want to have everything installed right up to the point of poking the chimney through the roof so the roofer can do the flashing while he is there already installing the new roof.
I want a safe, quality, long lasting venting system and am willing to spend extra for it.
(1) will buying online save me much money?
(2) if yes, which sites are best (I have been looking mostly at VentingPipe.com)?
(3) which brands are best (I am leaning toward Simpson Dura-Vent)?
(4) I am trying to glean as much helpful info online as I can about self-installation...any helpful sites or threads on this site (with diagrams especially for an installation situation like mine)?
(5) how high should I try to go with my chimney pipe above where it exits the roof? (I don't have a lot of trees especially close to where the chimney will be) It can be VERY windy here in central Oklahoma so that should limit the height, right?
(6) this is probably a dumb question but do I need a damper section of stovepipe? (the Jotul diagram does not show one)
(7) is it better to use fixed-length sections or telescoping stovepipe? From my rough calculations the top of my stove will be about 2 feet off the floor so I need about 6 feet of stovepipe, right? I would prefer to not have to make any cuts of stovepipe but will if thats better than telescoping. At what point do I need to stop my stovepipe vertical run (exactly flush with the ceiling or into the attic a bit)?
(8) is a "ceiling support box" recommended? (and what is it's purpose exactly?) Does the vertical length of this box figure into the amount of stovepipe I need or does the stove pipe run through it?
(9) what critical pieces of information do self-installers typically overlook???
Thanks so much for any information!
