jimosufan said:any one check water content......to make sure wood is seasond.....?
I do.jimosufan said:any one check water content......to make sure wood is seasond.....?
cptoneleg said:You folks scarring me with this 2 or 3 yr seasoning with oak hope I dont have to wait that long to burn my new stove. If so someone want to trade have 4 cords cut split and stacked 6 mo. come Nov. Cpt
Buy the MM and see what your dealing with first.
Cpt
maybe your problem is sticking it in then ends. You resplit it and just push in lightly with the grain on the inside of the split. No hard pushing.cptoneleg said:I have split the wood a lot smaller ( 2" 3" few 4" ) than usual , hoping it will season enough to burn. I have MM need to experment with some more. I caint stick prongs in the ends of the Oak splits. Will try when I get back home. I will have plenty over a year next season.
Any suggestions on how to get prongs in to get a decent reading will be apreciated.
Always wanted to go to Alaska
Cpt- of Va
To get an accurate reading you need to split a split in half and get the inside reading. The outside or ends will dry faster and give you a false reading. You also don't need to drive the pins all the way in, my instructions say 3mm.cptoneleg said:I have split the wood a lot smaller ( 2" 3" few 4" ) than usual , hoping it will season enough to burn. I have MM need to experment with some more. I caint stick prongs in the ends of the Oak splits. Will try when I get back home. I will have plenty over a year next season.
Cpt- of Va
cptoneleg said:I caint stick prongs in the ends of the Oak splits.
Cpt- of Va
Sorry Dennis, but your statement needs correcting. It should read The BEST way to have dry wood is to get it cut, split and stacked well before the time you need to burn it. It certainly isn't the "only" way.Backwoods Savage said:Never had one. Never used one. No plans on ever buying one. Once you learn what dry wood is you have no worries. The only way to have dry wood is to get it cut, split and stacked well before the time you need to burn it. Best is 2-3 years minimum time.
