CanadaClinker
BrotherBart said:Ours breaks pretty evenly between heating and cooling over the year and if I used 90 KWH in this house in one day somebody either here or at the electric company would die! I have the daily usage numbers for the last three years and heating this 2,500 sq. ft. all electric barn and two people with wood we have averaged 23 KWH per day over that three years. That's with the wife's tv and dvr running 24/7 and three fridges.
Bart... when the temp dips to -30 to -40C that's when all the stops are out and the heat is going full bore.... but my 90 is good compared to what I've see some people consume .......much more when their electric heat kicks in.... a 'large' house 5 down from me had a consistent usage during the -30 temps of 170 to 190 Kwhr/day..... but all electric heat along with a circulating hot water pump to make sure the water was hot when the tap was turned..... trouble was the hot water pipe went above the uninsulated garage... ouch! .... but I guess they didn't mind spending the $$$ for the convenince...
... not me.... I'm all florescent lights, extra insuation in the attic and walls, timers on this and that (including the van's block heater - 500W)..... but lots of glass in this house.... just replaced 2 X 72 inch square windows that came with the house with tripple pane, double low E, argon filled ($$$) to help reduce over the long haul along with improved comfort...... what we have to do to put a barrier between us and Old Man Winter!! :roll:
