hey folks will be installing my harmon p68 stove really soon. i was just wondering which ash vacuum should i get?
DexterDay said:Get a Good Shop Vac and use a "HEPA" Filter and a Fine Filtration bag on the inside. Will filter the Dust/Ash better than your average Ash Vac and also cost less. No matter what, you can not suck up HOT Ash with any Ash Vac out there. they all say to cool down before using.
This is the one I have in the basement for my "Pellet Sifter", but the one upstairs is the same. Also spend $40 on a Good Leaf-Blower for cleaning. My troy Bilt was About $40 and a $2 piece of 4" to 3" PVC makes it hook right up to my Vent. Put a little tape on it, so I dont have to hold it...
Looking forward to some Pics. The P-68
the problem with a shovel and pail is it can be very messy, dusty also it just does not do as good of a job .NATE379 said:What I figured. My free 5 gal metal pail and $5 shovel see to work just fine.
smilejamaica said:the problem with a shovel and pail is it can be very messy, dusty also it just does not do as good of a job .NATE379 said:What I figured. My free 5 gal metal pail and $5 shovel see to work just fine.
ya i did not catch that about the wood stove . and yes you do have to let the stove cool down its just the piece of mind with the ash vac . a few people i know burned up shop vac" s with cleaning the stove out before the ash cooled down .for the little bit of money it is, i think it "s well worth it. geez lets not skimp on the toys for the stovej-takeman said:smilejamaica said:the problem with a shovel and pail is it can be very messy, dusty also it just does not do as good of a job .NATE379 said:What I figured. My free 5 gal metal pail and $5 shovel see to work just fine.
Nate is using a woodstove. Metal pail and shovel should be all you need(it's all I ever needed anyway). I didn't get the vac until I purchased the pellet stove. Even the ash rated vac's would need some cooldown time if you really read the fine print.
smilejamaica said:ya i did not catch that about the wood stove . and yes you do have to let the stove cool down its just the piece of mind with the ash vac . a few people i know burned up shop vac" s with cleaning the stove out before the ash cooled down .for the little bit of money it is, i think it "s well worth it. geez lets not skimp on the toys for the stovej-takeman said:smilejamaica said:the problem with a shovel and pail is it can be very messy, dusty also it just does not do as good of a job .NATE379 said:What I figured. My free 5 gal metal pail and $5 shovel see to work just fine.
i agree with you 100% .oh ya i also leave mine outside after a clean . now im glade no bears ,pigs or other pesky animals know where i live ...they might get some crazy idea of sneaking away with it..lolj-takeman said:smilejamaica said:ya i did not catch that about the wood stove . and yes you do have to let the stove cool down its just the piece of mind with the ash vac . a few people i know burned up shop vac" s with cleaning the stove out before the ash cooled down .for the little bit of money it is, i think it "s well worth it. geez lets not skimp on the toys for the stovej-takeman said:smilejamaica said:the problem with a shovel and pail is it can be very messy, dusty also it just does not do as good of a job .NATE379 said:What I figured. My free 5 gal metal pail and $5 shovel see to work just fine.
DexterDay" date="1314854743 said:Get a Good Shop Vac and use a "HEPA" Filter and a Fine Filtration bag on the inside. Will filter the Dust/Ash better than your average Ash Vac and also cost less. No matter what, you can not suck up HOT Ash with any Ash Vac out there. they all say to cool down before using.
If safety is the forfront? Yes the ash rated vac's would ease the fear. But it also could lead to oops if overconfident. Don't get me wrong here, I will purchase the ash rated vac when my old bucket finally dies. I just don't want others thinking you can suck hot coals in the vac and not have issues. The filters in most are only made of fiber and do catch when hot coals contact them. After a clean I still will set the unit outside for at least 24 just in case as safety is first!
Still needs a good full cleaning and a brush ran through the vent. Do the leafblower after everything else is done. Or if you can get someone or something to hold the leFblower. I run it the whole time I clean.oldmountvernon said:DexterDay said:Get a Good Shop Vac and use a "HEPA" Filter and a Fine Filtration bag on the inside. Will filter the Dust/Ash better than your average Ash Vac and also cost less. No matter what, you can not suck up HOT Ash with any Ash Vac out there. they all say to cool down before using.
i finally see the leaf blower trick in action, how much cleaning do you do prior to the leaf blower ? or does the leaf blower do it all?
DexterDay said:I forget the name, but Menards here in Ohio had an Ash vac for like $50-$60. My buddy the has a CB 1200 like mine, Loves it. I still opted for the Shop-Vac. The stove should be cool no matter what vac you use. Even a Cheetah has to have a cool stove (Warm I believe is what they say). I have my choice of Filters and Bags (Fine Bags and HEPA Filter). No Dust/Ash in my house or my basement were the pellet sifter is... Only takes about a ton to almost Fill the bag of a 16 Gallon/6.5 HP Shop Vac, while sifting. No dust upstairs or downstairs. Granted the money I spent on a Vac that size, along with the HEPA Filter ($35) and the Filtration bags for the Inside, I could has bought a Good Ash Vac. But NO Ash Vac will Suck like a 6.5 HP Shop Vac. Before buying my Leaf-Blower, I hooked one up outside and sucked. It worked almost as well as my 450 CFM and 240 MPH Leaf-Blower.
Ash Vac have there place in the market. Shop Vacs do also. Some people need the reassurance of the "Steel" can. But like j-takeman said, the still have a filter that can smolder. So to each there own. We all have different stoves, different homes, different cars, and different jobs. everyone can be a little bias. Buy what you want and buy what you like. Just remember to practice responsible habits/behaviors when performing any maintenance/cleaning of any stove that contains a Fire.
Cheers ya'll.... Hope everyone has a Great, Safe Holiday weekend! I have to work tomorrow, but I took a Vacation day on Tues. That way I still get 3 days off. I have a Woodstove to install this weekend. Its gonna be cold before we know it.
Don2222 said:Hello
Hearth and Country makes a more affordable one. Looks like TSCs price is cheaper than Amazon!
http://www.tractorsupply.com/heatin...-country-trade-ash-vacuum-800w-4-gal--3102712
It is cheaper then these on Amazon
http://www.amazon.com/s/?ie=UTF8&ke...=aps&hvadid=4577851975&ref=pd_sl_90eyq5duho_b
oldmountvernon said:walmart has a small shop vac for 19 bucks tomorrow if it burns up big deal for that money
