Avalon Astoria Pellet Stove
KVLBRB
3
Kellyville
Need help on finding what could be causing issue with our Avalon Asotria (turning window solid black) - over the weekend the entire stove was taken apart and cleaned. Replaced rope gasket around door, clean out gaskets and combustion fan was replaced. Stove ran great for two days and now back to turning window black. Any idea's on what issue could be would be greatly appreciated.
Plugged up venting system?
Is the new fan an OEM? Double check to make sure it is the proper one for the stove - specs on motor. If the problem isn't with the fan, perhaps the board? Confirm settings are unchanged (fuel feed and air)?
Is the new fan an OEM? Double check to make sure it is the proper one for the stove - specs on motor. If the problem isn't with the fan, perhaps the board? Confirm settings are unchanged (fuel feed and air)?[/q
Thank you for the info, we're going to check that out later this evening.
