Blaze King cleaning
webby3650
Master of Fire
11,501
Indiana
The issue was discussed a while back of wether it was necessary to pull the pipe up and clean behind the cat. I always do and this is the reason why. I swept the flue with the bypass open, the pic shows all the crap that landed on the bypass and fell in behind the cat. Just pull your pipes up and give it a quick sweep with a vac, it should be easy to do and if its not, it might time to rethink your connector pipe setup.
Reactions: jeff_t
Wait. That is a King, not your Ashford.
My princess insert would get like that but being an insert I would contort my arm and clean it by hand.
The insert will get a little build up in the flue collar, but it can't fall in behind the bypass. The PI flue collar comes off of the stove at 30 degrees and the bypass opens toward the cat. So the junk just sits at the bottom of the 30 degree flue collar and can be easily swept out.
Doesnt seem like that much work for a COMPLETE job..............
Reactions: webby3650
Why not just suck it out from the firebox with a vacuum? Have you ever tried that? The good thing about removing the flue is that you can adjust that bypass tension bolt.
Yeah, I know you're baiting me here. I absolutely agree that the best cleaning will occur if you remove the flue. Surely you can agree that most people don't do that and no damage results from the remaining crumbs.
It's like cleaning a septic tank or the actual firebox. The last bit of junk you clean with great effort is not worth cleaning.
I concur 100% on that.
I didn't do it this last time and I could feel the by-pass closing on the crud!
So I will pull it soon!
Because you can't sweep it out. The bypass opens toward the cat, to protect it.Therefore it can't be accessed from below.
No baiting intended at all. I just want people to see what's going on under that pipe.
When the only tool you have is a hammer, everything looks like a nail.
I've done it both ways and removing the flue is a lot more work for what looks to be harmless crumbs. What damage do you think can happen from leaving those crumbs webby?
I've cleaned several that have gone a few years without being cleaned properly. I find a nice big pile of ash and creosote laying behind the cat, clogging the bottom inch of it. A good portion of it lands back there when the flue is swept, the rest falls throught the seasons and lands on the bypass. When the bypass is opened, it's flipped back toward the cat.
And as I have seemed to have found out it can make it so the by-pass does not seal correctly.
Reactions: bobdog2o02
Yes, one of my reload rituals is to reach in and brush that gasket clean with my fingers. That gasket is in a spot to catch junk every single time the bypass is opened. Regardless of how well you clean sweepings. Not sure how much junk it would take to cause a problem but an easy wipeout keeps it clean.
One thing is for sure... you can clean it spicnspan by removing the flue. I would hate to lose an inch, a good 25%, of cat function.
Well crap. I brushed mine with the lever on bypass just before heating season got serious.
FWIW I brush mine out a couple times every winter from indoors so I don't have to go up on the roof at 40 below.
Given our burn times how long do I have to let the stove cool before I can vaccuum behind the cat?
It'll have to be pretty much out. Because you will need to pull the pipe. How long has it been since it's been cleaned out behind the cat?
