Got a new king this is the 5th or 6 th fire. My set up running 35 foot interior insulated 8 inch ss liner. Got a 28 in rise before 2 45's into thimble. Using Kiln dried wood with moisture reading of 13 -16%. I dont feel the stove is putting out heat. So spoke to Blaze king tech support. Was told start a fire with kindling then add larger and larger splits only add when the previous has caught fire well. Leave tstat on 4 and load stove. Once cat gauge goes into active zone leave tstat on 4 and claose bypass. Then temp should rise steadly until desired temp and then you can begin to lower tstat in increments every 15- 20 minutes.
Ok so this is what I did Started fire with kindling and news paper and gradually and larger splits fire was going good kept adding as directed above. then loaded stove. Here is my data.
Time room temp Outside temp Draft(manometer inches of water column) Stove top temp Cat gauge temp Stove pipe
6 pm 69* 47* -.01 69* 69*
start fire
6:10 69 47 -.025 72 low deactive zone 107
6:40 70 47 -.03 170 just in active 180 engaged cat tstat still on 4
7:40 71 45 -.05 180 little past active 140
8:00 71 45 -.07 287 about 12 o'clock 200 setting at 3 slowly decreased every 15 minutes cat glow
8:20 71 45 -.075 380 about 1 o'clock 240
8:50 74 44 -.08 400 2 o'clock 223 slowly decrease tstat now at 2.25
9:05 74 44 -.08 380 2 " " 207 tstat 2.25
9:30 74 44 -.08 350 1 " " 180 tstat 2.25
9:40 turned tstat up to 4 caols begin to glow wood begins to glow after 15 minutes
10pm 75 43 -.10 500* 7 o'clock 310 tstat at 3.50
10:20 76 43 -.10 530 5 o'clock 274 tstat 2.75
I will continue taking readings and up data but what do you guys think ????
11:45 pm 78 43 -.11 700* 7 O'clock 340 tstat 4
DO I NEED AN IN PIPE DAMPER ???
start fire
