A well driller shared this tip with me. Rather than a flashlight, use a small mirror to reflect sunlight down the hole. You will be amazed at how well you can see, ha.
oldgrezmonke said:I have contacted the real estate agent to see if he can contact close relatives who might have knowledge of the place or find some record that includes this thing . Of course , I had already asked what it might be and the agent had no idea . I do not want to simply yank it open .
Artesian means it's under some pressure which will bring it up in the hole. If it is enough to bring it to grade, it is "flowing artesian". A desireable well...keep it for future irrigation or other uses.jdemaris said:artesian well sends water above ground level under some sort of pressure. If it doesn't, it's not artesian.
Highbeam said:I agree with jdemaris. I was trying to convey the same thought that unless it is a petroleum tank, it is no big deal. Either leave it alone, fill it with sand, or smash it in with a backhoe and backfill with soil. Whether it's poop, water, or a bomb shelter, it's cheap to get rid of and no reason at all to pass up a deal.
I had this happen with an in-ground swimming pool once at a house I wanted to buy. The seller was way worried that the pool was a deal breaker since it needed some work. To me, the pool was 500 bucks worth of pit run to fill it and some backhoe time to break the upper 3 feet into the hole. I did use the seller's fear to my advantage when dealing.
Semipro said:kenny chaos said:If it is a fuel tank, you could spend zillions and have to deal with the EPA. Dunno.
Many states have funds to help pay for this sort of thing. In VA, the cost to the landowner is limited to a max of $500 and most pay nothing. I worked in the environmental field for 10 years and ran across these sorts of things all the times during Environmental Site Assessments.
granpajohn said:Artesian means it's under some pressure which will bring it up in the hole. If it is enough to bring it to grade, it is "flowing artesian". A desireable well...keep it for future irrigation or other uses.
oldgrezmonke said:Just trying to get an idea with what I might be dealing [and how much I might get off the price] . I haven't dealt with buying many houses and never one this old so I wanted to tap into other's experiences .
sinnian said:You're in TN, probably part of a distillery!
