Cast Iron Steel Cylinder
DevilsBrew Posted By DevilsBrew, May 20, 2013 at 10:02 AM
  1. DevilsBrew
    DevilsBrew
    687
    232
    I don't even know where to start learning about this material. I am interested in the shelf life and general durability. Any suggestions?
  2. Jags
    Jags
    Moderate Moderator
    Staff Member
    Aug 2, 2006
    17,233
    5,916
    Loc:
    Northern IL
    Shelf life and durability of Cast Iron will depend on a ton of factors. Environment, Preventative maint., actual construction and intended use of the piece, the composition of the cast (metallurgy), etc.
    Cast has and is being used in all sorts of extreme environments. Think boiler pressure vessel, exhaust manifolds, brake rotors, wood stoves, etc.
    DB - I think I am going to re-route this post as it is not (so far) wood burning appliance(esk).
  3. DevilsBrew
    DevilsBrew
    687
    232
    It would be used for a riser. I admit to knowing next to zero about metals. I am starting to research what type of metal would be best.
    (It's cool, Jags. I'm used to DIY. :) )
    Jags likes this.
  4. Jags
    Jags
    Moderate Moderator
    Staff Member
    Aug 2, 2006
    17,233
    5,916
    Loc:
    Northern IL
    We do have a small handful of folks here that work with metal professionally. They may have some good resources to get you started.
  5. semipro
    semipro
    3,028
    461
    Loc:
    SW Virginia
    What are you looking to do DB?
  6. DevilsBrew
    DevilsBrew
    687
    232
    It would be used as a heat riser on a rocket stove, either outdoor or indoor. This comes from a suggestion to use a cast iron sewage or water pipe. Maybe that is different from what I have been googling (cast iron steel)? Not sure.
    To be blatantly honest, the only type of cast iron I am familiar with is my Lodge frying pan.
  7. Dakotas Dad
    Dakotas Dad
    1,455
    186
    Loc:
    Central Kentucky
    cast iron, and steel.. two different critters.
    MasterMech and DevilsBrew like this.
  8. DevilsBrew
    DevilsBrew
    687
    232
    Man, that would be heavy. Thanks, Dakotas.
  9. fishingpol
    fishingpol
    2,052
    1,130
    Loc:
    Merrimack Valley, MA
    Maybe visit a scrapyard on a not so busy day and ask a few questions. I have a cast iron chiminea and the flue lifts off the body. I've had mine outside for about 10 years and shot more flame up and out that thing. An inexpensive grill cover will help it last outside.
    Keep us updated. And pics, we like to see pics.
  10. Dune
    Dune
    3,128
    273
    Loc:
    Commonwealth Of Massachussetts
    What is your actual question?
    To be clear, there is little difference between cast iron and steel in terms of durability and or performance in heating appliances.
    The main differences;
    Cast iron is fragile for the most part (there are types which are not, such as ductile and maleable iron) and difficult to repair when broken (although possible)
    whereas steel is flexible and easy to repair when needed.
    Any supposed advantage cast iron has over steel in terms of heat resistance is a myth.
  11. DevilsBrew
    DevilsBrew
    687
    232
    Will do. I am going to start off small this summer. For the next 2-3 weeks, there is an obligation that I am attending to.
  12. DevilsBrew
    DevilsBrew
    687
    232
    I made the "heavy comment" after looking at an online picture of a cast iron pipe joint.
    Thank you for the advice. I need to do a ton of research.
  13. Dune
    Dune
    3,128
    273
    Loc:
    Congrats on the promotion Comandorf.
    Jags and ScotO like this.
  14. Jags
    Jags
    Moderate Moderator
    Staff Member
    Aug 2, 2006
    17,233
    5,916
    Loc:
    Northern IL
    Ahhhh...and there is one of the pro's I was referring to...
    (Thanks, Dune).
