Greetings all, long time lurker, decided to join after days of searching and reading.
Purchased a classic Bay 1200 last fall, installed it and it worked great. This year I've cleaned it all out (in august) done all the maintenance stuff to do, clean the blowers, ect....
Here's my issue, I'm using a new brand of pellets for this stove. (golden fire) I've used this brand in an older englander stove and not had an issue. This year, for some weird reason, I can't get the flame to balance out. I've adjusted my feed rate (turned it down because the flame is to tall) but it is so low, that the unit has issues starting. If I turn the feed up a 1/4 inch, it will start just fine. Trouble is, then my flame is to big, with the stove on medium settings the flame dances to the top, kind of a lazy-ish flame. It will burn down low, but then it shoots back up with the majority of the time the flame reaching the full heighth of the stove. I'm wondering if I missed something when I did my yearly cleaning. One thing I know I did not do, was to remove the fire pot, I just looked in it really well and brushed it out in place. (is it possible not pulling it out to clean it would cause this?) I had started to remove it to clean it out, but can't remember why I didn't now. Is it possilbe I disturbed a gasket?
What I did for my yearly cleaning was cleaned the exhaust, the air intake, the ash collector, the fans, exchanger tubes.
after countless hours of reading up, i'm not sure what to look for, I've gone around and made sure all the latches are secure and tight, even tightened them a little bit to make sure I wasn't getting any air leaks. I even have the tech service manual and i'm not finding ideas in it.
The stove also seems like it's not putting out as much heat as last year. Ideas?
Thanks.
dave
Thanks.
dave
