So can someone tell me what the differences are between a ceramic and steel baffle? Life? Performance? anything else you can think of...
Thanks
Thanks
ansehnlich1 said:My Jotul Oslo has a vermiculite baffle with about a half inch of rockwool insulation laying on top. They used to come with cast iron baffles, but the company says they moved to vermiculite due to a problem with the cast iron warping in the Oslo.
Highbeam said:Durock ? You mean like tile backer board? I thought that the durock would just crumble under the heat. Very interesting if it works since in a pinch, we all could pick up a piece at the local hardware store.
HeatsTwice said:Good catch. So far the ones I have installed have lasted all night without any signs of wear. They are as clean and "new" as when I put them in. That is there is no soot on them at all.
carp said:HeatsTwice said:Good catch. So far the ones I have installed have lasted all night without any signs of wear. They are as clean and "new" as when I put them in. That is there is no soot on them at all.
If you take them out, do they appear brittle? It's always hard to tell what is meant by "withstand temperatures to X". That could mean for it to still function in it's intended purpose. Just like it can only withstand 100 freeze thaw cycles.
I'd be very careful. Should they fail you may encounter a runaway fire. My baffles only leave a one inch wide opening at the glass to allow exit out the flue. Without them, that opening increases by a factor of 36 for me.
Now I wonder how they would perform wrapped in fiber blanket.
HeatsTwice said:They are fragile to begin with but after 10-12 cords they do get banged up (two years after purchase). The sell for $65 from the manufacturer. They still can be used but I felt I would try out this Durarock idea.
rumme said:HeatsTwice said:They are fragile to begin with but after 10-12 cords they do get banged up (two years after purchase). The sell for $65 from the manufacturer. They still can be used but I felt I would try out this Durarock idea.
you have burned 10-12 cords of wood in 2 years, in your napolean ? Seems like alot , ecspecially in California.
do you ever have any smoke enter your house from your stove, if its windy outside ?
Pagey said:My Endeavor uses a combination of steel supports and fire brick. I'm curious to see how well they hold up over time. That's a lot of constant heat, so I'm not expecting any miracles. But of course the tight wad in me is hoping for the best! ;-)
EddyKilowatt said:Pagey said:My Endeavor uses a combination of steel supports and fire brick. I'm curious to see how well they hold up over time. That's a lot of constant heat, so I'm not expecting any miracles. But of course the tight wad in me is hoping for the best! ;-)
The tight wad in you will appreciate, then, that you can replace every brick in your baffle for like ten bucks. You'll be the envy of every guy with a custom refractory baffle, on that day at least... ;-)
carp said:HeatsTwice said:They are fragile to begin with but after 10-12 cords they do get banged up (two years after purchase). The sell for $65 from the manufacturer. They still can be used but I felt I would try out this Durarock idea.
I have a 1400 and the baffles are fragile. Touch them with wood while loading or anything else and pieces will come off them or they will gouge. I haven't even put 6 cords through mine in 3 years and they are about toast. You can see where there may have been holes in the mold to cast the baffles. They look like little plugs and are about to fall out making holes.
I will not be spending a single penny on a Napoleon baffle.
Since I have about 65sqft of durock in the garage I may also test it out. My stove cools every day while at work so I can put a durock in just one side and yank it every day to check on it.
The 175 Degree temperature limit I noted for Durock above was directly from the manufactures F.A.Q. for the product.
http://www.usg.com/navigate.do?reso...ils/DUROCK_Brand_Cement_Board.faq.html#N20174
