I was wondering how long I can expect my chimney/flue to last? It's a 15ft, 6" stainless, double wall pipe. Lets assume, no over firing and using seasoned wood- ideal conditions basically. I did a search here but couldn't find the answer.
A good long time. We pulled out a similar 22 yr old Metalbestos class A system. It was in very good shape and made the recipient very happy. So I would guess somewhere in the 20-30yr range? Ask me then. Our new flue went in 2006.
Actually we have about the same average annual rainfall as NYC, just at a different time of the year. What we don't have is summer humidity which may have some bearing on aging. I would suspect living next to saltwater burning driftwood might be the worse case scenario.
any flue (whether it be stainless, refractory, tile) should be good for you for 20 yrs. I've seen alot of old 25+yr metalbstos chimneys in good shape that were installed in the 80's.. Chimney liners have been out there a long while, but the stainless and poured systems were not heavilly used (or required, for that matter) for a good many yrs. Older stove manuals will show the "porthole" method of installation: whereby you block off a fireplace opening w/ a sheet of steel (damper open, of course) and simply plug the pipe into a hole cut in the sheet of steel. No connector to the stove... I've seen this in current use in some older folks homes. It's scary, creosote all over the fireplace behing the sheet steel. But I digress... Point is the ss liner and poured systems have simply not been around in heavy use as long as prefab chimney systems, but I would expect life expectance around the same... especially if insulated (because at that point, its a metalbestos style chimney anyway).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
