Chimney through wall question concerning offsets
Mark Richards Posted By Mark Richards, Sep 4, 2013 at 10:24 PM
Thread Status:
  1. Mark Richards
    Mark Richards
    Member 2.
    NULL
    May 21, 2013
    79
    19
    Loc:
    Southwest Minnesota
    Where my chimney exits the exterior wall there is an overhanging smaller roof that I need to go around before I can run the chimney up to the soffit and through the roof.I plan on using a 15 degree bend at the chimney support with a 3 foot section of pipe and then another 15 degree bend to straighten it back up. My question is I have read that you can have no more than two 90 degree bends in your chimney from stove to cap. Does this mean I cant have more than 180 degrees of total bend in the chimney system or does it just mean you cant have three 90 degree bends.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,868
    8,622
    Loc:
    South Puget Sound, WA
    A pair of 15 deg offsets should be ok. Are the 90s on the connector and then at the tee? If so that is pretty common. More important will be the total height from stove top to chimney cap of the flue system.
    DexterDay likes this.
  3. Mark Richards
    Mark Richards
    Member 2.
    NULL
    May 21, 2013
    79
    19
    Loc:
    Southwest Minnesota
    Yep, there will be a 90 degree bend in the stovepipe to the class A chimney. Then the T section then the 15 degree bends. Total height of system will be approx 22'. Does this sound OK?
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,868
    8,622
    Loc:
    Yes, that sounds like it should work ok. Not perfect, but also not untypical. If you want to improve it a bit, use two 45s on the interior with a short connector to soften the interior 90. Be sure to brace the exterior piping well.
Thread Status:
