BakerB said:How hot does Metalbestos pipe get ?, and is it ok for it to be touching a little bit of wood going thru roof ?
SteveKG said:I have three chimneys of Metalbestos. The Metalbestos extends into the living space from the ceiling a bit, so I can easily touch it. After several hours of burning, it is often too hot to touch more than a second or two. You need that insulating airspace, at least an inch or so. The Selkirk spec's call for 2". Over some years, or whatever amount of time, that repeated heating of combustibles at the pipe can lead to combustion. Don't risk it.
SteveKG said:We actually have four. But three chimneys. The main heat stove is an old Shenandoah, been using it for 35 yr. If you are not familiar...they are barrel-shaped stoves lined with firebrick and are large-firebox things. One is a Rais, a kitchen model designed for both heat and baking. Great stove, small oven. That one has been moved out to occasionally heat an attached greenhouse and replaced in the kitchen by a Heartland Artisan, an Aga company, which is a full-service kitchen range cooker [or so they call it]. We've only been operating it a week and a half. The fourth is a small water heater, an "AguaHeater," I bought in the early 80s. It is a dedicated water-heating stove, used only for that so only every couple days for showers and only burns for a half hour or so at a time. The flue for that one is tied in to the flue for the Rais. So they share.
RenovationGeorge said:SteveKG said:.
Anyone know if there is spec or data on how hot a Class A pipe can get during flue fires? Not that it matters, I'm just curious, as always.
rated for 2100* chim fire if it is HT class a
Wood Heat Stoves said:RenovationGeorge said:Anyone know if there is spec or data on how hot a Class A pipe can get during flue fires? Not that it matters, I'm just curious, as always.
Wood Heat Stoves said:RenovationGeorge said:SteveKG said:.
the 2100f rating is for TEN minutes only!! (the ht pipe is rated for 1000f continuos use.) if chimney fires only lasted 10 minutes, the fire dept wouldn't even be on scene by the time it was over!
MINIMUM 2" CLEARANCE
