nealj said:Just fired up the owb first time this fall. It seems like my plate exchanger isn't taking as much heat off the owb water as it could. Has anyone done anything to clean one of these? It has been in service for 4 years Thanks for any replies.
dogwood said:HR, I was expecting the filter only to screen out extraneous junk that may clog the plates, not lime or calcium deposits. I do have a water softener on the DHW side. Where do you obtain the coil cleaning fluid you suggested earlier in this thread. I have run down the Webstone flush valves you suggested. Do you think the coil cleaning fluid would be better as a cleaner than vinegar. Or do you think periodic cleanings (descaling) of the flat plate might be unnecessary with a water softener in place. I do want to properly maintain the thing.
Mike
in hot water said:It doesn't take much scale to really start hampering the HX in those exchangers. Hard water and high temperatures are a problem for any HX surface. I like to install heat exchangers with these Webstone flush valves. It allows you to run a coil cleaner solution with a small pump to clean them out without removing or draining the system.
I have one customer that removes his and takes it to a radiator repair shop and has it "cooked" out.
hr
in hot water said:A couple wash machine hoses, buy the 5 footers or longer.
A plastic pump, I use these Little Giants and drop it in the bucket with the cleaner, diluted as instructed on the bottle. Those plastic drill motor pumps work, slower and you have to hold them, but they work fine.
Install the Webstone flush valves with the side port down by the HX.
Turn both of the large handles off, open the side port valves, connect hoses. Vice grip, or spring clamp the lose hose to the side of the bucket so it doesn't jump out.
Plug in the pump and watch what comes out.
Flush with clean water, some use baking soda or soda ash to be sure they neutralized the acid flush. Some brands of cleaners change color as the ph changes, some send ph test strips to assure you have it flushed clean. I think the RectorSeal/ Stewart Hall brand sends a neutralizer package with the cleaner.
hr
