clydesdqle or Jotul 550
pharmsaler
75
Western PA
Hey guys...I need your help and experience.
I have narrowed it down between a clydesdale (floor mdel $2699) or jotul 550 (floor model $2880).
Which one is better with heat output...assuming fuel is equal
Which one is easy to use? Best durability?best overall?
Most likely you will get an answer that both Clydesdale and Jotul 550 are great inserts.
I am attaching a comparison between these two inserts that I created during my search for a wood insert.
The Clydesdale has won over Jotul 550 because of installation flexibility (depth adjusting surround) and a better fit into our fireplace opening.
Two additional hours of heat life is a big plus too.
Reactions: Zerotonine
Cant speak for that specific Jotul insert, but Jotul as a company makes a great product. I sold them for 13 years or so on Long Island. The Clydesdale, with its HUGE glass and soft even heat, I sell a lot of. Always a happy customer when I sell a Clydesdale.
In my completly un-biased opinion you should go with the Clydesdale, but I have a feeling you are going to like whichever of those two you choose.
I was in the same situation deciding between these very two inserts 6 months ago...do yourself a favor and flip a coin.
I was in the same boat about a year ago and went with Rockland. Here are the reasons why
1) Jotul is a great brand - you don't go wrong with Jotul stoves. It's like buying a Toyota.
2) Cast Iron is more forgiving than Soapstone - If I overfire or do something wrong, Iron will hold better than stone. Soap stone might have natural variations (more prone to cracks)
3) Cast Iron stove gives instant heat Vs longer retention time of Soapstone
They both are great stoves and you won't regret your decision
________________________________________________________________________________________________________________________
I get what you're saying, but you're selling me more on the clydesdale. The jotul is a steel box with only a cast front. I think there maybe a small cast insert. The Clydesdale is a true cast iron all the way around. And I think the soapstone's have a warranty on them for a while ( I will have to check that out)
As far as the Toyota thing...I'm more of a Mercedes or BMW guy.
They are both great inserts.
Do you want one that is nearly flush with the front of the fireplace or one that sticks out further? I wanted a nearly flush one so I went Jotul.
For that price on a floor model I hope that is an enamel finish on the Jotul. I like wood stoves flat black as its less expensive and easier to refinish.
From what I can tell, both are good inserts. I know the Jotul 550 and am happy with it, but I expect you would get a similar response from a Clydesdale owner.
In my opinion the two aren't that much different. The Clydesdale is cast iron and does have soapstones in it as a refractory but it's not a soapstone stove. The cast will be slower to heat but should retain a little longer. The Jotul is a little more ornate with the details and is flush with the fireplace. The clydesdale is a little more simple looking with a solid glass door, but it is a huge window. I was sold on the jotul 450 and 550 but found a Clydesdale used and saved a ton. For looks I think the Jotul has the clydesdale beat but for heat I like mild even heat. I have a steel stove as well in the garage and it will cook me if I'm close. Not sure if steel inserts are this way since they have blowers but the Clydesdale is very even and comfortable for me. Local Craigslist ad here has a Clydesdale for $1,200 that is in perfect shape. It's already on a pallet and I bet the guy would ship it. Search Dayton, the insert is in Springfield directly of 70, about 3 hours from PA border, maybe less.
Clydesdale can be installed flush or sticking out.
I purchased the 550; my brother purchased the Clydesdale.
They are both great heaters and neither of us has had a single issues.
When I'm home to run it 24/7, the 550 is adequately heating an entire 2600 ft colonial to an average of 67-70F.
If it's 20F or warmer outside, I can easily exceed 70F.
My burn times run 3-4 hrs, but Im still new at this and I know the 550 can be better once I have proper burning mastered.
My brother easily heats~ 2100 sft with the Clydesdale.
2 happy customers.
Good Luck in your purchase.
Franks said:
pharmsaler, check your PMs if you havent already
I'm Sorry....What are my PM's..can anyone help...sore not use to the acronyms
KeepWarmInWinter said:
Franks sent you a private message (PM).
Thanks Guys for all your help!!! Tomorrow I'm going to pick up my new Jotul
No...I Didn't flip a coin....I asked the wife which one looks prettier...She ultimately liked the flush mount rather than the protrusion the clydesdale had. Also, when the clydesdale was pushed back as far as possible; there was a gap of about 1/2" between the unit and the surround. I didn't like that. We have 20 month old twin girls and I can imagine what would be shoved back there.
Before I install the Jotul I am going to get it painted a brown with metallic finish (hi temp paint) to match the brick a little better ( again to make the wife happier) She really liked the porcelain finish but the dealer kept telling us how much it would chip with a bang of a log? The paint was the next best solution
Be sure to take some beauty pics and post them here. FWIW, Jotul porcelain is pretty tough, especially the blue-black enamel. Our 30 yr old 602 has very few chips on it with little babying.
I wanted a fireplace that extended into the room , but my wife wanted a flush mount. In a spirit of compromise, we chose the Jotul 550. You will enjoy it. Tonight it's 15 degrees outside and with the insert 73 inside.
