Corrosion in Avalon Olympic insert? Are repalcement parts needed?
Cleartron
14
Norwalk, CT
Hi All,
I'm very new to wood stoves and burning wood. I have been using our Kamina on the main floor to heat that part of the house just fine. Today, I went downstairs to light a fire in the Avalon Olympic insert since it's pretty cold out and noticed that the inside of the insert has a squarish divot. Is this supposed to be like that? I'm afraid of lighting a fire if this could cause harm.
Any advice on what I can do to keep it running (replacement parts?) would be great.
Thank you in advance.
Corrosion in Avalon Olympic insert? Are repalcement parts needed? Corrosion in Avalon Olympic insert? Are repalcement parts needed?
Do you know the year for this stove? Does the stove have 3 secondary tubes under the baffle? If so, that is the foot of the secondary supply plenum.
Reactions: Cleartron
it's actually newer than I thought. I previously thought it was from the 80's. I just found the manual and installation pics that the previous owner left. The brochure has a copyright of 2005
Corrosion in Avalon Olympic insert? Are repalcement parts needed? Corrosion in Avalon Olympic insert? Are repalcement parts needed? Corrosion in Avalon Olympic insert? Are repalcement parts needed?
I wanted to come back and say thank you. After seeing the picture you included, I was able to see what needed to be replaced. I went ahead and bought some fire brick and cut down the ones that needed it. Replaced the broken/cracked ones for a mid-winter repair. I plan on doing a more thorough investigation when I don't need the stove (in case more parts need repair/replacement)
Cheers
