Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
cracked quad castile burn pot
Thread starterDMKNLD
Start date
My 10 year Quad Castile ceramic burn pot finally gave out and has a hairline crack in it . I know they make a newer generation replacement steel burn pot, do I need the new burn pot linkage or will my old one work?
I think I remember someone else with this issue, and it was said they needed the linkage also. Any thought to just having it welded? Mine is the same vintage as yours (2001) no cracks yet...........
I thought about welding it also, but the crack goes almost all the way between two adjacent burn pot holes. I bet the whole burn pot has been heat stressed enough over 10 years that it would likely fail in another place, so I might as well replace it once and be done with it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
