Hi,
I purchased a Lopi Revere but have not received it yet because I am in the process of installing cultured pro alpine ledgestone over my existing fireplace, and laying down a slab of bluestone for the hearth. I am pretty sure that the surround panel size I need is 8 inches all around. I was wondering if anyone has this setup so I can see some pictures of how it will look.
Do I put the ledgestone over the entire front of the fireplace and do my best to set the surround up flush against the jagged ledgestone? Is that how people do it? Or, do some people choose to have the surround sit flush against the existing brick and only install the ledgestone around the surround? The latter here sounds strange because what if I decided to remove the stove, then it would look silly with the old bricks exposed, right?
One more question. If someone has done this, did you use corner peices of stone around the opening or end the stone at the opening and maybe mortar over the exposed brick on the inside of the opening?
Thank you for your help!
