I am majorly impressed, Snowy! Have you ever looked at the Cublok systems? Very inexpensive and can be programmed either in Basic or Ladder Logic Diagram (which I like better). http://cubloc.com/product/01_01.php
DirtyDave said:correct me if I am wrong, but did not someone else post a different timer source in this thread that was not 250.00 min order?
Here is a copy of a schematic that I have used to rewire a couple older Pellet stoves.
Had a member ask about it, so here it is for all to use.
Things can be tweeked a little here and there to suit the specifics of the stove being retro fitted
The timers came from Precision timer company (Find on the web)
The main burner control timer (heat control) is a series 646 and the one shot timer is a series 644
These are not expensive and will be made to suit at the time of the order.
120 volt input/output solid state and are about 2 inches square and about 3/4 inch high.
The main timer I used has a pot on the controller to set the feed motor on time (1.5 to 2 seconds) and the off time (heat range) is controlled using a remote panel mounted pot and can vary from 2 seconds off up to 10 seconds off.
Most all of the original stove components such as feed motor, fans and such including the safety snap switches (low temp and high temp) can be reused from the original parts.
The snap switches are a universal item and can be purchased in various temps to suit the need.
The speed of the convection fan can be controlled using a standard CassaBlanca fan speed controller that is available from the hardware store.
These are a basic Triac with a round Knob to control the speed.
This is a very simple control setup, and will work fine for many of the older stoves that have become a parts orphan.
Hope this helps
Snowy
Hope this helps
Snowy
