Don't know why, but the cw2500 likes to coal up a lot more than the 602. Maybe I try to flog this one too much. But anyway, out of a 3 hour burn cycle, I spend the last hour at least waiting for the coals to burn down. If I reload too early, I end up with more than half the firebox full. I've tried raking coals, forward, adding a single split, etc., without success. Basically, I need more air to the coals to burn them down, or better yet more surface area exposed. Has anyone made a device to help burn down coals faster? Two thoughts were:
a) A couple of metal perforated tubes that you jam into the coals,
b) A perforated metal shelf that sits above the coal bed. Shovel some of the coals on top of the shelf, and poof, 3x the surface area exposed.
c) Kinda like b, except that you have a 3 sided metal mesh box with multiple compartments in it. Shovel in the coals, partially filling each compartment. Throw the whole thing back in, and now you have airflow around the coals in each compartment.
I'm thinking b is the best combination of what would work v. what I would actually do (I think c might work better, but way more work to implement).
Whaddya think ("you need a bigger stove" isn't an acceptable response).
