Pellet1
Dug up this old thread while looking for an answer. I found the correct paint and now the stove looks like new again. It was installed in time for Christmas and it added so much warmth and cheeriness to out LR. The whole family was impressed by the stove. And a friend was so impressed that he went out and found one just like it to replace his existing insert. I still have not replaced the ignitor element(too expensive), but the stove is not a regular burner and so I have opted to use a small propane torch to light it. Works well.
My question is this: How does the combustion air inlet work? If you connect the inlet to a pipe from the outside, the air is drawn up against a baffle and out into the back cavity of the stove and then is sucked back into the stove thru a small hole with a sensor installed in it. With this setup, it seems to me that much of the combustion air would be coming from inside the house, as the front panels are less than airtight. Why is the stove set up like this, and what may be the workaround?
