Dremel jig?
Easy Livin’ 3000
3,018
SEPA
I cannot hold the correct angle when sharpening chains. I intend to build a jig to hold my Dremel at the correct angles. Anyone done this that can share their experience?
If you already have the file n joint all you need is a way to clamp your dremel to that jig. That should take care of all your angles minus the stop, which is nothing more than a thumb screw.
At $75, is it worth RE?
I also use the dremel. I hose clamp a manual chain file guide to the dremel. Did it years ago. I use the angle from the manual file guide, while using the dremel.
I have that, too. Having a tough time imagining how to clamp the dremel to the manual file guide. Any chance you have a picture with the dremel attached?
One hose clamp
There are lines on the dremmel gaurd. I merely make sure the line is parallel with the angle of the tooth and go. Never had a problem that way.
I've tried that for years. There are some of us who are artists and some not. I'm no artist, and have a very unsteady hand. I gave up on freehand for good in 2017.
LOL, fair enough.
