I am worried about evenly heating the rooms in the house. I have a hot air system presently and will be installing an insert. If I turn on the fan occasionally on the furnace will that distribute the heat thru out the house? Does anyone do this?
I can understand a ceiling fan distributing the heat evenly in each room, but I can't see how they would push it thru out the house. That is why I was wondering about running the furnace fan.
I found that running the furnace fan to distribute the heat had a minimal effect in my house. I feel your pain, ssman, as I searched long and hard for answers like that and found that what works for one person does not necessarily work for others. There are too many variables - room layout, stove placement, leaky ductwork, etc. As kinsman stoves said, trial and error is going to be your best bet.
Two things to consider, one is all of the duct work insulated? If the supply side is insulated consider warping up the return side there is not as much for duct work as the supply. If not try it any way to see if it works. Second where is the furnace? Is it in a cold location or is it in a heated area? If it's in a cold location the main body of the furnace is usually not insulated in might not work with the lower settings on the pellet stove, but might on higher settings. The only way to find out if it works is to experiment and tinker a little bit. It's all ready in your house no reasoned not to try it.
Celling fans, regular fans, muffin fans, to move heat form form to room will work. It's just a little ugly running fans all over the house during the winter. But the mufin fans are most likely to be the best, they can be tucked in the corner of a door way cornner and places like that. The only thing you need a outlet for the plug near by or will have to add/replace the cord.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
