england pellet stove hopper extension ????
TROY COOK
139
Ramsay, Michigan of the U.P.
hello, has anyone made a pellet hopper extension for a england stove?? I don't think it would be to hard?? thank you to responders!!!
There used to be a guy on eBay that made them, but they are NOT recognized by Englander, and their use will void warranty.
A hopper extender sure would be nice. It seems with the 60lb hopper you never really get the last 10-15lbs to feed before the stove shuts off. Not sure if its the sawdust that makes it stick to the walls or not.
I HAVE HAD THAT CLINGING PROBLEM..I GUESS SANDING SIDE WALLS OF HOPPER AND USING ARMORALL WORKS?? ALSO ALUMINUM TAPE APPLIED TO SIDE WALLS..
I use fine steel wool and a hand vac to get particles, and then use furniture polish, or car wax would work as well. Some people rub with wax paper. Aluminum furnace tape works well in corners.
