Englander 25 puf
rellimd
3
Western Pa
I have an Englander 25 puf, upon start up the stove works fine but after 20-30 minutes it seems the stove goes into a type of standby mode the fire burns and pellets keep feeding but barely keeping the stove running. Last owner had a thermostat connected but just cut the wires off could this be the problem or is this a programming issue. PLEASE HELP
Thank You this sounds like that is the problem, I just want to make sure i am putting jumper on right terminals. It mentions two different numbers J-18 and J-3 do you know if these are just the same terminals on two different makes of stove? i believe the jumper just bypasses the thermostat again thanks for your help i just want to make sure.
That could very well be the case, perhaps there has been a factory change. I don't have any first hand experience with a thermostat but saw the info in my 25PDVC on how to install one. As I understand it the thermostat merely closes the circuit and the jumper accomplishes the same thing. Based upon what I read, wherever the thermostat was connected should be replaced with a jumper wire to operate without one. Perhaps someone else could shed some light on the different terminal numbers or contact Englander Tech if this doesn't work. They will probably need to know the model and serial of your stove.
Make sure to start the stove on 5-5 and manually adjust to suit yourself. Do not leave on the 9-9 thermostat recommended setting.
