enviro maxx too much heat
kathee b.
4
MA
my house is 80 degrees, how do i turn the heat down on this enviro maxx? combustion trim level is 3, heat level is 1 and feed trim is 1. my house is so hot!! any ideas?
That stove is a heat beast at 60 thousand btu
Suggest you put it on a thermostat. Auto /on/ off
that way you can control the output
In real cold weather, you can use auto Hi/Low
On manual this time of year even at the lowest
setting it will blow you out of a tight smallish house
Welcome to the forum
Reactions: kathee b.
thank you. thinking of just trading it back in!! only a couple months old. house is about 2400 sq ft and it's driving me crazy! miss my 20 year old harman!
I use the same stove in my 2600 sq foot shop and on high heat even on the coldest days will
blow you out of the place. So I use high low on a stat. keeps it comfortable and if the shop
door is open too long it kicks up too high and warms the place back up quickly.
If you are used to a Harman it will take a while to learn the Envrio. Whatever you do I wish you the best
thank you for the information!
See page 15 of your manual
