New burners, hang in there. In a couple years you'll be lovin' it too!Having dry wood is so nice. My first year in the new house I started many many soggy hissy fires.
I just let the stove go out for the last couple days. Sure, the temp in here dropped several degrees by the time I fired up again but OTOH, I got to enjoy the pleasure of doing a top-down start when I finally loaded up again. Sorry you are missing out on all the fun but maybe one day, as you've thought of doing, you'll get a Woodstock, come out of retirement, and re-join the ranks of the real wood burners again.Kindling, wow! I haven’t really given it a thought for a few years. With the Blaze King I rarely ever do a cold start after the season kicks off. I used to keep lots of it on hand for easy and constant restarts...
cedar was my favorite.
Real wood burners! ....?I just let the stove go out for the last couple days. Sure, the temp in here dropped several degrees by the time I fired up again but OTOH, I got to enjoy the pleasure of doing a top-down start when I finally loaded up again. Sorry you are missing out on all the fun but maybe one day, as you've thought of doing, you'll get a Woodstock, come out of retirement, and re-join the ranks of the real wood burners again.
That's right, manly burners, not kids with training-wheels thermostat stoves!Real wood burners! ....?
I don’t miss starting fires at all! I would like to try a Woodstock. Not a soapstone model though, I’m not a fan of sending most the heat up the flue.
Maybe. But a Prius is a Toyota. A BK is, well, a BK.Wonder if the guys on the car forums tout say a prius like BK's are here. I can hear it now...."wow a gas station, i havent thought about them in years"
Well, whatever all that means...Yep, manly burners, not kids with training-wheels thermostat stoves!
I don't see much difference between running a stone stove, or a stove with steel sheets inside the box, preventing the heat from getting out. I don't think I'm sending all that much heat up the flue once the stone is warm. That load in the pic, that I'm burning now, has the air set at 1 on a scale of 4, and the flue meter is reading right at 300. That's a meter lying on top of the stainless tee snout, about 6" behind the rear flue exit. Gotta be hotter there than it would 18" up a vertical connector pipe. It would be interesting to see what a probe at 12-18" up the liner would read. I'd need a thermocouple for that. I may do that some day, and hook one up for the cat exhaust as well. The hole provided on the back of the stove requires an 8" probe, and that's too long to accurately transfer actual cat temps all the way to the dial. Or I could drill a hole in the top of the stove and drop in a shorter probe, as Todd did..
One of my goals in my posts is to befuddle, baffle and beflummox those unfortunate enough to stumble across them. Mission accomplished!Well, whatever all that means...
