    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. jetmech Member
    Dillsburg PA
    Woke up to 29 degrees here in South Central Pa.. T5 is earning its keep, top is 630 and its got the house at 74 really good frost this morning.. Could be a cold winter in store
    #1
    Helpful Sponsor Ads!
    raybonz likes this.
  2. NH_Wood Minister of Fire
    southern NH
    Had our first frost this morning too, but working on the 10th fire or so - quite a run of raw, rainy weather over the past couple of weeks. Glad you are toasty! I think we might be in for a cold winter as well. Pay back. Cheers!
  3. metalsped Member
    Hardwick, MA
    Based on how active, and how long, the squirrels and chipmunks have been storing up acorns... we are in for a cold, long winter indeed. The animals know better than we do.
  4. Backwoods Savage Minister of Fire
    Michigan
    Still not much heat needed at these temperatures. Winter will be colder than last year.
    Now jetmech, rather than overhauling that jet, I suggest you overhaul that avatar. I hate having to lay down to look at it. ;)
    milleo and raybonz like this.
  5. corey21 Minister of Fire
    Soutwest VA
    There is a cold front passing by me Monday been really warm so far this weekend.
  6. Wood Duck Minister of Fire
    Central PA
    My first overnight fire was last night. It was about 27 degrees here in the morning.
  7. raybonz Minister of Fire
    Carver, MA.
    Not easy installing a stove on the wall!
  8. Slow1 Minister of Fire
    Eastern MA
    Think that is hard, imagine reloading...
  9. raybonz Minister of Fire
    Carver, MA.
    LOL yup need to wear a firesuit!
  10. hockeypuck Member
    south central NH
    Lit one tonight... well season maple and a big wood brick from TSC..
    raybonz likes this.
  11. raybonz Minister of Fire
    Carver, MA.
    Interesting purple flames! Had to let my stove burn down or make the house too hot.
    Ray
  12. Backwoods Savage Minister of Fire
    Michigan
    So now he has a new avatar. Pretty good one too.
  13. When a stove burns at 630 or 700, is it producing way more heat than a similar size firebox stove that isn't capable of burning that hot? This is a real question I have been wondering for some time, even if the answer may seem obvious to some on here; I never knew.
    That T5 must be cranking the heat at 630
  14. Backwoods Savage Minister of Fire
    Michigan
    Some will depend upon the mass of the stove. For example, your soapstone stove has good mass. The heat from a soapstone will also feel much different from the heat from a steel stove.
  15. What is the max temp on a Progress Hybrid? That has about 700 + pounds of mass.
    Anyway, glad that the O.P. was able to burn this hot. Should be keeping warm
  16. Backwoods Savage Minister of Fire
    Michigan
    I think most are getting 500-600. I've not heard of anyone running it any hotter and most don't want that much either.
  17. raybonz Minister of Fire
    Carver, MA.
    Dennis we've had this discussion before and I agree that just because a stove is capable of running at 600+ degrees doesn't make it a good idea on a regular basis. To me it's like driving a car at redline RPM all the time because it can do it.. I would expect a reduced stove life running it flat out. If you need to operate a stove at 100% to get enough heat then you need a larger more capable stove! Like so many things in life moderation will enhance longevity..
    Ray
  18. jetmech Member
    Dillsburg PA
    Hey guys thats on the upper end of normal. i try to keep it at 600 or below. but its easy with good dry wood for this thing to get hot and stay hot. i also have a fan on it if i need to cool it down. As far as the avatar my oldest son is a deployed Marine, he comes home next Sunday after 8 months overseas, lookin forward to homecoming.
    raybonz likes this.
  19. Backwoods Savage Minister of Fire
    Michigan
    That should be a sweet homecoming! Our hats are off to him.
  20. raybonz Minister of Fire
    Carver, MA.
    Your son coming is great news Jet! I thank him for his service to our country!
    Ray
  21. jetmech Member
    Dillsburg PA
    Thanks guys, he only has 3 months and hes getting out. been a wild ride, this deploy was a MEU but he was in Afghanistan in 2010 for 7 months .. back to the stove, this is really my first year with really good dry wood. what a difference it makes, my stove is in a large room about 500 sq feet and heating the rest of a long ranch house. only issue is i have to keep a eye on flue temps during start up. they can go up pretty fast
  22. raybonz Minister of Fire
    Carver, MA.
    Until your son returns home I'm sure you'll be anxious! Hang in there..
    I find the flue surface temp on my T-5 will run up to around 500+ surface temp then it settles down. When talking stove temps earlier I was referring to those who try to sustain 650 and higher stove surface temps all the time. I do get spikes of 650 stovetop surface temps but don't try to maintain that temp and it settles in around 550 or so.
    Ray
