    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. ArsenalDon Minister of Fire
    Meadow Valley, CA
    So I have double walled insulated flue pipe inside going to the outside which then is Class A pipe...Disclaimer....I think I am recalling this all correctly from listening to my installer....the question is, I have an IR thermometer, is there a formula or a way to know using the IR what the temp is inside by shooting the outside? I can get an outside pipe temp of course but wanted to have an idea of what might be the temp inside.
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    Not really. I have tried this and found the results to inconsistent. A probe thermometer will provide much more accurate readings.
  3. bag of hammers Minister of Fire
    Northern ON
  4. Jags Super Moderator
    Northern Illinois
    There is very little correlation to surface temp of double walled insulated pipe to the actual internal temp. Something as simple as what stage of the burn you are in could yield drastic differences in your reading. Get a probe and get the facts.
  5. ArsenalDon Minister of Fire
    Meadow Valley, CA
  6. ArsenalDon Minister of Fire
    Meadow Valley, CA
    is a probe easy to install?
  7. Jags Super Moderator
    Northern Illinois
    A drill with the appropriate sized bit. Done.
  8. certified106 Minister of Fire
    Athens, Ohio
    Definitely get a flue probe....... they only require drilling a hole through the pipe and sliding the probe in. You will feel much better knowing what the actual flue gas temps are doing.
  9. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Two bits in my case . . . one smaller than the other . . . I forget the exact sizes.
    A 5-minute job with the first four minutes being me worried about somehow messing things up and destroying an expensive piece of doubewall pipe and so I read and re-read the directions.
    Trilifter7 and rideau like this.
  10. Jags Super Moderator
    Northern Illinois
    Good call. It should have said bit(s).
  11. bag of hammers Minister of Fire
    Northern ON
    Don't forget to remove it before you run a brush down the pipe. Just saying' (oops).....
