Front-to-back lighting technique
dreezon
173
Peoria, IL
After learning about and trying the top-down method, I modified it. I stack the wood higher in the back and lower in the front. Then I put some paper in front an some kindling on top of that. This way, the flames get swept across the splits toward the outlet in back. Usually works well for me. Anyone else do this? Is there some disadvantage I'm not seeing? Seems like a good hybrid approach, I think.
Sounds like you need to approach BeGreen on the "tunnel of love" method :coolsmile: . Same kind of concept with the exception that the flame travels under the wood. I believe that this yields a flame contact pattern that accelerates the startup.
I think we need to go back to calling that a "cave burn".
I tend to stack the wood higher in the back than the front . . . but for another reason . . . keeps wood from rolling up against my glass and dirtying up the glass . . . at least for a while.
I do a similar, modified top down on cold starts... Big splits on bottom, smaller spits on top of that, then paper or super cedar or fatwood ( your choice) then kindling, splitter scraps. Paper lights scraps and kindling which fall to splits. Just a minor modification to the top down that works for me.
If it works well, don't try to fix it; just keep doing what you are doing.
