well, after so many of you all agreeing on the fan trick I ventured out to Target...no fans, Walmart....no fans, Home Depot....no fans. I guess its the wrong time of year to be selling fans. No one had them. The only fans I have are pedestal fans that sit about 4-5 feet high. What I'll do for now is try to use the woodstove blower to blow the heat towards the fan and use the fan to blow the heat down the hallway....hopefully into the bedrooms. I'll have to order a fan. I like that stanley fan that amazon has.
thanks guys
btw, for long term I was thinking about having my HVAC friend hook up something. What I had in mind is a HVAC return vent in the living room with a small blower in the attic, and then ducts in the attic to vents in the ceiling in the bathroom and both bedrooms. I'd have a HVAC type thermostat in the master bedroom to control the blower. I'd have it set so that when I use the woodstove the living room gets hot and prevents the heatpump from turning on, then the bedroom will get cold and the thermostat will trigger the blower to come on.
There are times when I work night shift and sleep during the day with the door closed. So no heat will be able to make it into the room via a fan circulating the heat.
just a thought
