    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Benchwrench Member
    State of Confusion
    I was hoping someone could mention a method of cleaning baked on pitch and something to help free up rusty kinks from abused chainsaw chains.
    Was considering an oil/mineral based solvent of some kind like I used to use to clean carburetor parts. That stuff was called "parts dip" and it worked well, you were supposed to let it soak overnight,so I was looking for something like that were I could just soak the chain then air blow it clean. (maybe diesel?) Whatever product, it needs to double as a moisture barrier so the chain doesn't rust like a water based product would.
    Any recommendations?
    #1
    Helpful Sponsor Ads!
  2. Backwoods Savage Minister of Fire
    Michigan
    WD40
    Benchwrench likes this.
  3. Boom Stick Feeling the Heat
    Capital Region, NY
    oven cleaner. Lay it on a plywood scrap or whatever and spray it, give it 5 minutes, toothbrush, done......takes care of pitch right quick.....
    jatoxico and Benchwrench like this.
  4. Boog Powell Minister of Fire
    NE Ohio
    Nothing after that, no kind of rinse or anything needed, sounds easy!
  5. CaddyUser Member
    New Brunswick, Canada
    I havn't tried PineSol on chains, but I've been using it on carbs for awhile now, and it works well. I'm trying to get away from using mineral based solvents....
  6. Thistle Minister of Fire
    Central IA
    My chains dont stay idle long enough to rust... lol .Not much sap or pitch on that nearly petrified Red/White Oak either.Occasionally it builds up when milling green/semi-green wood,but gets cleaned off on drier stuff.
  7. MasterMech Minister of Fire
    Hudson Valley NY
    Some kind of penetrating oil to free up the rivets. Maybe buy a gallon of your favorite and soak the chain in a dish/bucket. For chains that have sap/sawdust stuck on them, make sure they're sharp and then run 'em through some Oak with the saw oiler cranked up. Works pretty good as "chain floss"! ==c
    Also, Stihl sells a spray for de-gunking hedge trimmer blades that I could see working well. Very $$ tho.
  8. DexterDay Minister of Fire
    NE Ohio
    Some type of Mineral Spirits?
    I have a Coffee can that I let mine soak in for a day or two before sharpening. Helps to clean them and remove and residual oil so my files last longer.
  9. Benchwrench Member
    State of Confusion
    I was thinking of diesel or something that wouldn't be flammable.
    The thing about the rust is due to forgetting that a chain was left in the weather and now has kinked up from the rust.
    I thought diesel might be a good start then just run it through some ash or oak, which might give the rust something to think about next time.
  10. MasterMech Minister of Fire
    Hudson Valley NY
    Coca cola is supposed to be pretty good at eating rust. Haven't tried that personally tho.
  11. bogydave Minister of Fire
    So Cent ALASKA
    +1
  12. nate379 Minister of Fire
    Palmer, Alaska
    I use Stoddard Solvent, but mainly because I happen to have a parts washer in the garage so it's handy.
    Usually my chains stay pretty clean, but I did throw a few in a bowl of solvent for a week or so. I had forgot them in the back of my truck for a couple months and they got pretty nasty.
  13. lukem Minister of Fire
    Indiana
    This is the first I've heard of anyone cleaning a chain. If the links don't move freely I'd probably hit them with a shot of penetrating oil spray (Liquid Wrench or whatever) and be done with it. They'll loosen up plenty after a couple cuts.
    WD40 works good at cleaning pine pitch, as others have said.
  14. basod Minister of Fire
    Mount Cheaha Alabama
    Acetone and transmission fluid.
    I save drained tranny fluid as it doesn't need to be clean.
  15. Benchwrench Member
    State of Confusion
    The reason I mention a cleaning technique is for the chains that aren't going to be put in service right away but waiting to get sharpened without wanting to handle gummed up chains while sharpening then storing them until needed. I thought there should be a procedure/process going from a spent chain to a clean sharpened chain staged to be put in service.
  16. BravoWhiskey New Member
    NY Southern Tier
    There's your answer. And you can mix ATF in with the chain oil to prevent gumming up when cutting sticky wood.
  17. Benchwrench Member
    State of Confusion
    Instead of a bucket I found that a 2" PVC tube filled with cleaner enables the suspended chains to soak out of the way
    Pallet Pete and MasterMech like this.
  18. Como Minister of Fire
    Colorado
    Lye is the cheapest and probably nastiest but most effective.
    Also use in Meths production so difficult to find.
    Sodium Hydroxide.
    There is a local company that refurbishes commercial kitchen equipment and that is what they use.
  19. Como Minister of Fire
    Colorado
  20. amateur cutter Minister of Fire
    West Michigan
    Yep, although I use new fluid to avoid any grit that may be in the used. If you're about flammability, just use the ATF. Very high detergent + lubricity. A C
  21. trailmaker Member
    Northern California
    Vinegar might be worth a try. It does wonders on rusty axe heads so it might work on chains as well.
  22. HDRock Minister of Fire
    Grand Blanc, Mi
    Best penetrant ,50 50 mix, Acetone and transmission fluid.
    I use pitch and gum remover, (spray can) on table saw blades, and have used oven cleaner on them, both,will remove,pitch and gum
  23. jatoxico Minister of Fire
    Long Island NY
    Oven cleaner also works very well on dirty glass. Not as big a problem for me as it was last year. :cool:
  24. flhpi Member
    Southern Ohio
    I like the coke idea. It does wonders for my Jack Daniels.
    Pallet Pete likes this.
