First, I wanted to say thanks, I've spent the last week reading all the stickys, and reading thru answers on forums.
We've settled on on a wood insert, to be installed in a preexisting masonry box with tile chimney that is centrally located in a two story 3500 sq ft house with the staircase in the same room. The house is all electric (no gas, no oil, just a furnace in hair-dryer mode in the winter once the heap pumps can't keep up) in central Ohio climate.
We have an expectation of getting supplement heat, since our house square footage is larger than the metrics of fireplaces. We just want to reduce our $900+ per month electric bills. (Baseline electric during months of no heat/no cool is around $150.)
We are considering the Hampton CI2601 (Regency HI400) vs Quadra-Fire Voyageur Grand.
On paper, it seems the CI2601 seems better - more BTUs, better efficiency, longer burn time, larger firebox, all at about the same price. I've also seen some folks here mention the Voyageur needs the door left open when starting, not something I like.
But then I saw this (at the time of this post) 34-page response on the catalytic converter-based wood-burning inserts here:
https://www.hearth.com/talk/threads...-ci2600-fireplace-insert-risky-costly.132252/
It seems folks are OK with the catalytic converters stove like this one, but it also garnered a LOT of replys - in fact, it is the predominant thread I found on that insert. It seems like a lot of folks are having issues getting 14 hour burn times, but overall it seems folks aren't scared of catalytic converters, and like the designs of the HI400/CI2601 and seem happy with the unit as a whole.
Any direct comparisons between these two stoves I would welcome.
Thanks!
Thanks!
