Well, haven't had great luck with the door on my stove.... I had it installed on Wednesday and had noticed that the door wasn't sealing very tightly on the bottom. I noticed when the stove got hot and had a roaring fire, the air being introduced into the stove on the bottom would flare up. All this with the draft closed completely... I looked into the manual and it stated how sometimes the door needs to be adjusted from the factory so it seemed straight forward... Remove the latch on the stove and remove a small washer. Simple enough so I thought.... I took one of the three washers to adjust it in as small increments as possible. The door closed rather tightly after this and also still allowed air in the bottom. I looked at the gasket and it wasn't rolled and was in the correct location correctly adhered as well, so I just lit it up anyway to get some heat. I ended up getting the stove really hot to the point the secondaries were glowing and left the blower on high to cool things down a bit. We were home with it just slowly cooking much of the day. I had just some hot coals in the stove and closed things up before heading out for the night... I came home to a big split from top to bottom on the glass... It is definetly due to the way the door is closing as I haven't had this stove cooking very much at all. I'm hoping that Hampton does something about it... I'm going to see if I can get a replacement door as I'm not sure that this one is cast correctly... Has anyone every had any issues like this? I'm just curious also how square the hinges are.... They are welded on so there is no adjusting....
