hard cement stuff to seal corners inside stove ?????
Chrism
326
Eastern PA
what do i use (INSIDE THE STOVE) to put in the seams of the stove to make it air tight ?? its a cement kind of stuff hard as a rock
Stove cement. I use Rutland but I think there are others out there. You can buy it at a local stove shop and most hardware stores carry it also.
Will (homesaver stove gasket cement) work??? The guy at the stove shop said it would but I see its gasket cement?? He's not the brightest guy in the world.
Just check the temperature rating on the cement. If it is going to be inside the firebox I woul go with a higher rated cement.
One thing to be aware of is that just troweling on furnace cement on a flat surface normally doesnt last. Generally you need to have a gap to fill in like two bricks butting up to one another. If its just spread into a corner like window caulking it will normally pop out after a few temperaure cycles.
There are ways of covering up surfaces that usually entail instaling a steel mesh on top of the sruface and then troweling the new stuff into the mesh. It may still delaminate eventually but usually stays in one piece.
