    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. smirnov3 Feeling the Heat
    Eastern Ma
    I am thinking of replacing the Distribution fan on my Harman accentra insert with a quiter model.
    does anybody know what the specs of the standard fan are?
    obviously, it can push at least 135 CFM, but is that the maximum rated, or does Harman run it slower than rated?
    What is the model number of the fan (Mine doesn't say anything on it)?
    What is the dB level that it is rated for?
    any help would be appreciated
    #1
    Helpful Sponsor Ads!
  2. smirnov3 Feeling the Heat
    Eastern Ma
    Anybody? anybody?
    C'mon guys, I want to void my warrantee already!
  3. MCPO Minister of Fire
    Any decent motor shop or (motor repair shop) would be able to get you an exact replacement. Probably a lot less than one from a Harman dealer would be.
    Harman doesn`t make this fan themselves and in all probability it`s an off the shelf motor and impeller .
    My 25 yr old Nashua wood stove used the same or a very similar one .
    However finding a quieter one might be a lot harder to do.
    It`s possible that by dampening the fan mount it would result in a quieter operation.
    You might want to check how hot the stove gets at the fan mount and maybe place a reasonably even bead of high temp silicone on the fan , let it cure and then bolt it back onto the stove to act as a cushion. But keep in mind some of the noise is from the air velocity itself and that a certain volume of air being forced through a small pathway , opening , duct is going to make a certain amount of noise anyway no matter how quiet the fan motor and impeller might be.
    John
  4. kilarney New Member
    Vermont
    As an Accentra insert owner myself, my sense is that the bulk of the noise is from the air itself. But I do wish you luck and hope you keep us updated.
  5. Dont ya wish they could use the same blower for all of them?Anton the advance is a grainger blower, yet it is not the same for accentra.Quick question though do you have the medium and low voltage winding wires like in the manual specs..
    Anyway echoing Giovanni My former motor supplier was in Woburn....... First electric motor they could most definitley identify it for you......
    www.firstelectricmotor.com
Thread Status:
